Engine Heater Light (Panel LED) Problem
ezee |
3 Dec 2009, 08:43
Ezee Group: Members Posts: 53 Joined: 4 December 07 From: India |
Mahindra Renault
Logan DLS 1.5 Diesel
roland |
3 Dec 2009, 12:27
Membru autentic Group: Members Posts: 2.704 Joined: 18 November 04 |
As far as I remember, that indicator is for both pre-heating the spark plugs and for electrical problems.
So, you may experience electrical issues of any kind. Maybe also the relay which commands the pre-heating goes on (and the led also goes on) which should not happen. A visit to a Dacia/Renault service would be useful. |
Keka |
1 Jan 2010, 22:59
Logan driver :P Group: Members Posts: 113 Joined: 30 May 07 From: Novi Sad, Serbia |
As far as I remember, that indicates water in diesel fuel filter.
You have to go to the service. |
2004 1.6 MPI Laureat pack LPG by Dora
- Kadett 1.6D 1983
martin245 |
6 Feb 2010, 10:40
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
YES Its water in the Filter !!
That light is a water in Filter sensor light Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
ezee |
19 May 2010, 19:26
Problem rectified ... actually it was a manfacturing problem for all pre 2009 Logans in India becuase of inferior quality of wiring.
There is a white color wire in plug which powers engine and its bit short in length and tends to get loose and create a warning/problem in electrical system, resulting in pre heat light goes on. They attached a piece of wire and shouldered again .... problem solved !! |
Mahindra Renault
copros |
21 Nov 2010, 18:18
Membru incepator Group: Members Posts: 7 Joined: 7 June 10 |
congratulations for problem solved,if you have anymore problem on lights,welcome to contact me for help.
BMW
volvo
- 18765 www.hid-copros.com Profeestional on auto lighting such as hid kits,canbus ballast,led bulbs,canbus led bulbs,bixenon lens,daytime running light.
prince1 |
20 Jan 2011, 13:17
Membru incepator Group: Members Posts: 1 Joined: 20 January 11 |
Yes, this is a manufacturing problem you can contact with expert engineers.
Thanks |
Corrola
2010
2010
lglogan |
5 Aug 2011, 18:58
Membru incepator Group: Members Posts: 1 Joined: 5 August 11 |
@ezee: "Problem rectified ... actually it was a manfacturing problem for all pre 2009 Logans in India becuase of inferior quality of wiring.
There is a white color wire in plug which powers engine and its bit short in length and tends to get loose and create a warning/problem in electrical system, resulting in pre heat light goes on. They attached a piece of wire and shouldered again .... problem solved !!" Hi, I have following problem: Dacia Logan 1.5 DCI, 70HP, produced Dec 2010, now 16000 km. Only when climbig hills on the hightstreet with 110-120 km/h the preheating indicator goes on. A few minites after the hill it goes out. In the city and in the mountains (60 km/h in 4-gier) it does not go on. The visit in Dacia service was without any success. Ezee, could you please give me a more detailed discription which cables and plugs you have checked! Any other idea is wellcome! Many thanks in advance |
Logan sedan
2010
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th June 2024 - 01:58 |
